Drafting image plane
I want to place a reference image to a surface on a CPlane to use as a guide for modelling but can’t see how? Please could I be directed to a tutorial or guide?
Thanks
Hi Gavin -
It’s probably easiest to just drag and drop an image into Rhino and use the Picture option.
thanks, I’ll try that. I previously (years ago!) used Maya and could mapped an image onto a plane to use as a curve guide
that works - many thanks
Hi Gavin -
You can do that in Rhino but you then have to have that plane in Rendered mode to be able to see it. You’d also need a plane with the correct aspect ratio or mess with the mapping. When you use a Picture object instead, Rhino does that automatically.
