I’m trying to add a new layout with the “Copy Layout“ command in Drafthorse while also running Rhino.Inside. The component returns the “object not set to an instance of an object” error and no layout is created.
There seems to be a general conflict while running this plugin along Rh.Inside.
I’m running the latest versions of Rhino. Revit and Rhino.Inside. on Windows 11.
