Draft Angle Analysis won't create draft curves in Rhino 8.5
What it says in the title. Just updated, tried to create draft curves in the Draft Angle Analysis dialog box.
I click the button, nothing happens.
Anybody else having this issue? The rest of the tool works.
Do you have an example file? Here it still works.
So, I tried restarting my machine, and this is now a little weirder.
Draft curves worked after I restarted, then I worked for a while and draft curves began failing to happen again. I doubt my file is going to show you anything, but here it is. I’ll try to recreate the conditions that make it start failing, and get back to you.
draft fail.3dm (639.0 KB)
I could repeat it here.
My suspicion is that it stops working after opening a second file.
second file open simultaneously or consecutively?
consecutively:
RH-80483 Draft angle curves don’t get generated on second file
