Draft Angle Analysis for only positive angles?
This new tool seems to be to analyze where positive and negative angles are, and create parting lines for tooling.
But how do I set up the tool to check for angles between 0 - 0.5 degrees?
Is this the correct method?
I’m just slightly confused, because the graphic on the left implies that red only appears when there’s a negative angle…
…so, if you put the minimum angle positive (ie no negative angles in the analysis), should the graphic symbol on the left perhaps change to indicate this?
Robert -
Would something like this remove all confusion?
Yes, that looks very clear!
