Hello Wim,
I would like to give the static Zebra-Analysis a push. LINK
Could this be moved to 8.x instead of a future release target?
Best regards
Hello Wim,
Best regards
I would gladly use it in Rhino 7.x instead of 8.x
This release targets for issues are in a state of flux. I wouldn’t put too much meaning into an issue marked as future right now.
Hello Steve,
thank you for the reply!
I dont quite understand. Does it mean not any time soon, or that it might be pushed to 8.x at some point?
Best regards
This could be either 8.x or post 8. We still haven’t determined what can be added to V8.
Ok, i see!
Thank you!
Hello Steve,
I would like to ask if any decisions have been made yet?
This is excellent thank you @Trav! . I’ve been using this to locate parting lines in ceramic moulds.
No decisions have been made yet. The current pile of Rhino 8 projects that are underway is large and I don’t want to add new items to the Rhino 8 list until we have completed some of the existing projects.
Yes I understand. I will still try to bother you guys.
Thank you for the reply!
@stevebaer thanks for sharing the draft angle and zebra analysis. Has been super helpful thus far.
Hi Steve,
just wanted to say thank you for the static Zebra!
Here is a more complicated definition that more closely mirrors the UX of the the draft angle command in Rhino. Both Clustered and unclustered, for folks’ convenience.
Draft Lines continuous.gh (87.7 KB)
I also attempted to solve the problem of getting continuous draft lines when there are planar surfaces with a zero draft angle. Instead of duplicating the borders of these surfaces, my definition creates a line across them. If you use this, please try to break that function so we can make it more robust.
I find it very useful to be able to produce a single mid-draft curve for CNC toolpathing and I bet mold makers would find it useful too. It’d also be great to have a simple ribbon offset component to go with this.
There are a lot of situations in which this is geometrically impossible, I understand.
There are also situations where the Rhino command bugs out and fails to produce a continuous draft curve when it should be possible. I’d love to know if there’s anything under the hood, like tolerances, that might make it possible to fix that issue in a GH component.
