I am trying to use the Download Export functionality in Shapediver with the Viewer API v3. I have 3 different downloads set up in Grasshopper - for stl, dxf and 3dm.
I managed to do it back with the v2 of the API, but I simply cannot find a concrete example how to do it with v3.
This was my v2 code:
function exportFile(format: string) {
const exportApi = api.exports.find((exportItem) => exportItem.name === format);
if (exportApi) {
exportApi.request().then((response) => {
const link = response.content[0].href;
console.log("Use this link to download the file: " + link);
window.location.href = link;
There is a page for the IExportApi here: IExportApi | Viewer but once again I’m not sure who this documentation is for. It’s definitely not relevant for actually learning how to do things with the API. I guess there is a difference between a documentation of the API and documentation of how to use the API. The first simply shows what’s there, but the second shows context and examples. I have taken part in many courses around Grasshopper and Coding and there all you do is go through examples. That’s how you learn to use something. Just showing what each part is and how each individual part works will not really teach you much.
Maybe that is something to consider for the documentation. A very good example of this is W3School. For example: JavaScript String Search. They document everything around CSS, HTML, JS and more and each page has at least 1 example, usually several.
Anyways, can you provide a code example how to request a file download using Viewer V3?
Ahhh. I see. I could not find that section, because it was in “Session”, which I did not know is where it is. In the search results it’s actually only in the 9th position:
So I think I finally pieced it together from the examples (non of which used a button to download a file) and with some help from ChatGPT.
The TypeScript code is:
// Download a file from a button
// read out the export objects with the specific names
const stlExport = session.getExportByName("download-stl")[0];
// get the download buttons elements
const stlButton = document.getElementById("download-stl");
// function to handle export download
async function handleExportDownload(exportObject: any) {
// request the export
const response = await exportObject.request();
// get the download URL from the response
const downloadUrl = response.content[0].href;
// create a link element
const link = document.createElement("a");
link.href = downloadUrl;
link.download = response.filename || "exportedFile";
// simulate a click on the link to start the download
link.click();
// add click event listeners to the download buttons
stlButton.addEventListener("click", async () => {
await handleExportDownload(stlExport);
My export in Grasshopper is called “download-stl”.
The id of the div around the link is also “download-stl”.
Not quite the one-liner like just having it download when it loads the viewer, which I cannot think of many use-cases for that.
The other examples where for requesting an Export with File Parameters and the other was for exporting using authentication tokens, which is nice, but very specific.
All 3 examples either just log the export to the console or download it straight away upon loading.
