Double to float conversion problems
Hello
It is not first time when this kind of error occurs in my grasshopper algorithm.
I have arc with its origin in 0,0,0, but when i use deconstruct plane component it outputs me not 0,0,0, but somewhere very near this point. I know that this is very little innacuracy but those kind of erros can build up and at the end innacuracys may have significant values.
Whats the best way to:
  1. Spot places where innacuracys occurs
  2. Deal with those kind of errors.
Your initial circle is probably just a little bit off of the origin…
Here I’m referencing a circle which I created on 0,0.0001,0
The B (plane) output only shows two decimals.
You could create a filter to visually distinguish which circles are on an exact point without any decimals…
