A nice feature would be using Double Click to bring up an object’s Properties box. Doesn’t seem that Double Click is “mapped” to anything currently. Would be a convenient feature - just sayin’…
-d
-d
Isn’t this possible to set in custom mappings?
Anyway, the shortcut key for Object Properties is ‘F3’. I’d rather have double click function to to an edit within a Group. Same as you have in Adobe Illustrator.
I use the Right-Click for that. Editing Groups is more of a specific case, whereas I would expect Double-Click to work on general things. Object Properties would seem a more logical for that, imho.
cheers-
david
or for block editing… BlockEdit
is not yet implemented on mac but i assume double-click is being reserved for it… (as in-- i think with rhino for windows, you can edit a block via double-click)
(fwiw, this is the same way sketchup works for component editing)
