When making a annototation “DOT” it is not possible to toggle on and off snaps, which is needed.
Thanks for the report, I’m not seeing this here though in the latest daily build. I can toggle Osnaps and Grid snaps while placing the dot. Were you doing something different?
Ah, I meant while the dialog box for typing is up.
It’s far from a huge thing, but it makes Rhino feel unresponsive in a way we are not used to
I see what you mean now, thanks. This does differ from v5 where you can toggle snaps while the dot dialog is up. Although you can’t yet use them but I know what you mean. Filed as https://mcneel.myjetbrains.com/youtrack/issue/RH-42652
