Doors and windows Families from Revit to VA get no parametrization at all
Hi @fsalla the original goal was to be able to change the sizes of the windows I transfer from revit to VA. But then I had a problem with the grasshopper file which the create window style component seems to be not working, since I was feeding it propperly (I only mas the same connections that was made with columns).
I could bake revit objects to VA since they were not doors and windows, which I could transfer them to rhino, but it wouldn’t change sizes, and achieve this parametrical hability is the goal.
I would like to know how I can import the window as a block with all parameters, as the original definition. How can I do this?
@fsalla I think is almost there! Initially it was getting nothing but then I added “1” to a list item to cull curtain wall, it got almost everything running smooth till the end which had some problems as the images are showing:
It seems that after the blocks are getting exploded, they are getting multiplied and without order inside them when reach the final component.
@fsalla Any idea what is happening?
