I have a GH definition that creates Revit walls using Rhino geometry as input.
Once the walls are in Revit we will attach doors to them. The problem I’m having is that if the wall gets updated (e.g. moved) then the door disappears.
If I use a face-based family then the component doesn’t disappear but it doesn’t stay attached to the wall.
Is this normal behaviour or am I doing something wrong? I have the tracking mode set to Enabled - Update
Hi @Japhy, not asking for the solution, but asking whether there’s likely to be a solution. Our proposed workflow is sort of dependent on this, so if it doesn’t work we’ll need to find another solution or a different alternative altogether.
