Door Parameters
Greetings everyone!
Is there a way to get the “Door Handing” property (if it opens from left to right i.e.)?
Thanks!
Thats a FamilyInstance.HandFlipped property, which as far as i know (not much) isn’t available as a component yet and would need to be coded.
Here is a quick python version.
import clr
clr.AddReference('System.Core')
clr.AddReference('RhinoInside.Revit')
clr.AddReference('RevitAPI')
clr.AddReference('RevitAPIUI')
from System import Enum
import Rhino
import RhinoInside
import Grasshopper
from RhinoInside.Revit import Revit, Convert
from Autodesk.Revit import DB
doc = Revit.ActiveDBDocument
def get_all_flips():
    familyinstances = DB.FilteredElementCollector(doc)\
                      .OfClass(DB.FamilyInstance)\
                      .ToElements()
    docs = [x.HandFlipped for x in familyinstances]
    return docs
L = get_all_flips()
GetRevitHand.gh (2.9 KB)
@Rickson
thanks so much for the response. I made a few modifications to the component so it can be used to check all various flip type, and updated the Wiki
https://www.rhino3d.com/inside/revit/beta/guides/revit-modify#flip
