Hi
I had a problem with the door axis control. Unlike windows, it does not give the option to choose whether to place them flush outside, inside or centre.
Hi @caterinasalvatori, doors, and windows work in the same way. You can change the door alignment from the Properties panel. You can also enable the door control points to change the opening direction:
Hi @fsalla,
I found the same problem only when I start a project from VA template. Conversely when I start with a rhino template this problem does’t happen.
I found that only for door command.
Thank you
Hi @fn_a, @caterinasalvatori
I don’t know what you mean. The insert options of doors and windows are the same in any file. When you insert them, the opening side is determined in the second click (when they are inserted in walls), and afterwards, it can be changed from the Properties panel. The alignment can be edited while inserting the object and afterwards.
Let me know if you see something different…
Hi @fsalla,
I attached a short video to explain better the issue.
Thanks a lot
recorded_test_door_alignment.rar (8.8 MB)
All right, I understand it now.
What happens here is that in VA templates, the door frame takes the width of the wall thickness, and for that reason you cannot appreciate the change of the alignment (defined by style).
On the other hand you are expecting the leaf to be aligned in the interior-center-exterior position according to the frame, but that’s not possible. Not in Windows either. The door/window alignment is in relation to the door/window frame and the wall thickness, but not to the leaf position within the frame. This is a feature we can add in future versions.
Thank you @fsalla,
It would be appreciated!
Hi @fn_a I let you know that in VisualARQ3 we have added an option to control the Leaf Alignment in relation to the Frame component, as you requested:
Hi @fsalla,
thank you for update.
It would be useful to get an option to define the doors dimension by net width and net height as well (not only by gross dimension).
Do you think is it possible to develop this option?
Thank you again
Hi @fn_a we have this request on our wish list, but I don’t know when we will implement it. You can already create doors that have the “net” profile dimensions with a Grasshopper style.
