Domain Question
So my question here is what nodes do I need to add to have the ability to change the height and width of the 8 sections? One section is longer than the other and the widths are going to have a variable range. Ideally I’d like to have 3 of the panel be the same size and the 4th across being the remainder of the section. Anything you guys can give me would be incredibly helpful.
FACAD_SCRIPT_2.gh (17.7 KB)
if you really want somebody on forum to help you, you need to:
a) internalise initial surface;
b) be more explicit about your task.
I apologize I thought my task was clear. As you can see the highlighted section was divided into 8 parts. That surface is now split and the output that I am trying to achieve is to have a numerical slider that can change the height and width of the sections. For instance the top 4 panels would have a height of 28 feet, the bottom 4’s height would be the remainder of the surface. Same principle for the width of the sections. Where the first 3 from left to right would be uniform and the 4th panel would be the remainder of the highlighted section. I’m sorry If I didn’t express that very clearly.
If i got it correctly this might be a solution…
DQ_RE.gh (16.0 KB)
