Domain Divide2 & Isotrim Not evenly spaced
I’ve created 4 curves to make a freeform surface. When I use Divide Domain 2 & Isotrim the segments aren’t even although the surface has been reparameterized. So I’ve setup a divide curve, interpolate then do the whole domain & isotrim again. This time it’s uniform. Is there a way to do this without the slightly longer method? Maybe I’m missing something? See images attached.
Isotrim_Surfaces.gh (13.8 KB)
Try to rebuild your curves from the first place before making edge surface.
Awesome, that did it. Thank you!
Thanks @dale, was in such a rush forgot to check the category.
