Does SubCrv have a limit? It doesn't parse entire curve
Attached is an image of a SubCrv issue I’m running into.
After making an interpolated curve, it should have 16,496 points as seen in the Control Points panel.
I would eventually like to subdivide this into sections, I have done it successfully with a curve with less points, however this high point curve seems to have issues.
In the attached picture, I set my subdivision to 1, Should this not equal 16,496? If I subdivide it parts, it seems to still stop at total 6,160.
Thanks!
I think you misunderstand curve domains. List length of a control point list isn’t giving you anything in correlation with a curves domain (except polylines).
Capture
You should be doing something like this:
Capture1
Wow, this fixed the issue right up!
Thanks!
