Does Rhino have a, "relative move command"?
Some other cad programs that I have used have allowed you to enter coordinates to move to relative to the selection of part of an object. Using the selected objects selection point as the equivilent of 0,0. For example if you want to copy and move a rectangle 20 units positive in X and 10 units positive in Y from the objects center point is there a way to do this without specifically identifying the rectangles center point coordinates and the destination coordinates?
http://docs.mcneel.com/rhino/5/help/en-us/user_interface/unit_systems.htm
Well, THAT’s handy!
Thanks Dale the @ sign before the coordinates does what I needed thanks for the quick response!
Couple of typos?
Surveyor (distance<N/Sangle E/W)
(This is under Construction Plane Coordinates; apparently discourse doesn’t like the angle sign)
World x,y,x
