Can I load 32bit native C++ (wrapped dll) on Rhino 6 Grasshopper ?
Or it must be 64 bit?
The reason for asking is if I build .gha file with 32 bit I get error:
An error occured during GHA assembly loading:
Path: C:\Users\vestarta\AppData\Roaming\Grasshopper\6\Libraries\OpenNest\OpenNest.gha
The GHA file is either damaged or has been made with
a newer version of .NET than Grasshopper itself.
You can try toggling the "Memory Load" option in the
GrasshopperDeveloperSettings command window, it might help.
And if in 64 bit it runs without error
