Hello, everyone!
I would like to ask you a question concerned with Wallacei X, Grasshopper. I would like to be maximize two fitness objective. So, I tested connecting them with negative component and one over x component scripts.
When I connected with one over x, I got a lot of output decimal fitness values like the attached screenshots below. But I did not want to be decimal as one of the FO value is the count of the object. Is there any way or any component scripts to be able to get the actual values of each FO. Or is negative scripts better to be maximize? If you have any better ideas, could you explain it to me?
I also attached the .gh file so that you could check it. Thank you all for always supporting! Have a good day!
WAllacei-test-edit.gh (42.2 KB)
