What is the preferred method to apply different materials in a rendering? Do you need a distinct object for each material? Can you split the surface of a single object in order to accept different material applications? Do you add a very thin object over your model elements for material applications?
Simple example attached. Also, the window has a frosted glass material applied which you can’t see very well; why?
Thanks,
Thomas
