Does a Split cutting edge have to protrude beyond the object to split?
e.g. I made a cube, then drew a polyline as the cutting object from corner to corner using snaps. However, the split failed. If I stretch the polyline beyond the cube it works. I expect I am doing something wrong, as this would mean using snaps on objects to draw split cutting lines does not work and a further step is required.
Hello - I see that and it also works to pick the exact-sized line up off of the top surface.The cause appears to be related to pulling the line to the target object - when the line sitting in the top face is pulled to the box as a whole, it gets pulled to the side faces as well:
When it is off that face it is pulled to the top and bottom faces:
