The German command list at Rhino Befehle [McNeel Wiki] seems incorrect, as it lists “Anmerkungspunkt” for “Dot”, while the correct command in Rhino 7 is “BeschriftungsPunkt”.
Note that the documentation changed from “BeschriftungsPunkt” to “Anmerkungspunkt”, however in Rhino 7 the command did NOT actually change and still is “BeschriftungsPunkt”.
https://docs.mcneel.com/rhino/6/help/de-de/commands/dot.htm
https://docs.mcneel.com/rhino/7/help/de-de/commands/dot.htm
(I’m not a German speaker, just trying to help a German speaker. I have not checked other commands.)
Note that I did initially installed the English Rhino 7 and later added/switched to the German version for testing, and also have the (English) Rhino 6 installed.
