dut_a_25k.3dm (2.5 MB)
Version: Rhino 8 SR32 (8.32.26160.13001, 2026-06-09), Windows 11
Not tested on later service releases (SR34/SR35 are available): I don’t have administrator rights on this machine and can’t update Rhino. If this no longer reproduces on a current build, please let me know.
Repro (rhino3dm 8.32.2, synthetic file; dut_a_25k.3dm, 2.5 MB, also attached):
import rhino3dm
f = rhino3dm.File3dm(); f.Objects.AddPoint(0, 0, 0)
S = ["SecOpen", "SecSubject", "SecDescription", "SecClose"]
for i in range(25000): f.Strings["%s\\%d" % (S[i % 4], i // 4)] = "value %d" % i
f.Write("dut_25k.3dm", 8)
Open the file in Rhino 8 with the Document User Text panel docked, then run _DocumentText.
Expected: about 25k entries load in well under a second, as other 25k-row tables do.
Actual: the UI is unresponsive for 18 s with the panel visible. With the panel hidden it’s 45–50 s, which is not understood (see below).
Measurements:
| Entries | Panel load (OpenPanel call) |
GetKey(i) for every entry, headless doc (no UI) |
Cost per GetKey |
| 1,000 | 0.13 s | 0.015 s | 10 µs |
| 5,000 | 0.76 s | 0.30 s | 52 µs |
| 10,000 | 2.85 s | 1.13 s | 105 µs |
| 25,000 | 17.4 s | 7.13 s | 270 µs |
| 50,000 | 70.5 s | – | 542 µs |
Cost depends on table size, not position. At 25k,
GetKeyon the first 200 entries took 54.5 ms and on the last 200 took 54.1 ms. Opening the same file headless (RhinoDoc.OpenHeadless) took 0.018 s, so reading the file is not the cost; each indexed read is. -
UI blocked while opening the 25k file, measured as main-window
WM_NULLtimeouts:Panel state Blocked Visible 18.05 s, one block Hidden 45.5 s and 50.2 s (two runs) Panel event watchers disabled by reflection 42.9 s Adding objects, rerunning
_DocumentTextand toggling the panel afterwards cause no stalls.
Analysis (IL inspection of Rhino.UI / RhinoCommon 8.32):
- The panel’s load routine makes 2n native calls.
UserStringsPanelControl.LoadDocumentStringsloops overStringTable.get_Count→GetKey(int)→GetValue(string). That is 2n calls intoCRhinoDoc_GetDocTextString/GetDocTextString2, each O(n) by the timings, so O(n²) on the UI thread. - When it runs:
EndOpenDocumentandActiveDocumentChangedsetUpdateDocumentStrings, andPanelShowntriggers a load. The idle handler (RhinoApp_Idle→LoadDocumentStrings) has no visibility check in its IL. - Not attributed: why opening with the panel hidden blocks longer than with it visible. No third-party assembly calls
StringTable(IL scan of every loaded assembly). - The same pattern exists elsewhere in RhinoCommon.
GetSectionNames,GetEntryNames,DocumentUserTextCountandDocumentDataCountall loopGetKey(i), so every plug-in that reads the table pays O(n²) too.
Suggested fixes:
- Make indexed access O(1) natively, or add a bulk accessor in one native call (e.g.
StringTable.GetAll()returning key/value pairs in O(n)). - In
LoadDocumentStrings, use the bulk call, or at leastGetValue(int)instead ofGetValue(string). - Skip the reload when the panel isn’t visible. Merge the reloads from
EndOpenDocumentandActiveDocumentChangedinto one. Load off the UI thread or in steps (RH-84210 asks the same for the attribute panel). - Rebase
GetSectionNames,GetEntryNamesand the count properties on the bulk accessor.
Related: RH-94017 (fixed in 9.x, attribute panel, managed side), RH-76189, RH-84210, RH-53945.
