Docker support
I got the error running during the docker,
Is there a reason that you’re using such an old version of Rhino 7 (ver 7.4)? Have you tried installing a newer Rhino 7 build on your Docker container?
Hi @AndyPayne No. I have not yet examined the new rhino. Which newer build are you referring to?
Could you please tell me if you have any documentation on rhino dockerization with load balancing and auto scaling on AWS? I want rhino compute to run in docker rather than a VM.
Unfortunately, I do not have much experience with Docker so I’m not much help there… But, the latest stable Rhino 7 release is 7.35.23280.19001. I think if you’re able to update your Rhino version, you may have better success.
@AndyPayne Still, the error was present. Also, how can I obtain the API key when using rhino compute in Docker? I want to connect API using key ?
@will Hey!
Do you know if it’s possible to build this Dockerfile on Windows 11? I’m getting The container operating system does not match the host operating system. type of errors.
I tried to change base image but to no avail.
