Do you know any way to flatten double-curved surfaces?
I want to flatten double-curved surfaces to create upholstery patterns for sewing chairs. However, I’ve tried the UnrollSrf, Squish, and Smash commands, but none of them have produced the results I’m looking for.
I know about ExactFlat, but it seems to be quite expensive and requires a paid license.
Does anyone know of an alternative method or a plugin that can flatten double-curved surfaces for upholstery patterns?
In Rhino 9 beta I would try Rhino AI and see what it does with it.
If you want, share a file of a pillow or a chair or whatever you have in mind and I’ll gove it a try.
You could try UV unwrapping, placing the seams where you would for tailoring, like one would do in Maya or Blender.
So that’s not what you would do for a pattern for that at all, obviously.
I agree, I’m just playing around with Rhino AI and I wanted to see what it comes up with.
Flattening double-curved surfaces is utterly meaningless without knowing how the material is going to behave when it is stretched and compressed, once surfaces start getting squished around the input could be literally anything as far as NURBS are concerned.
If you don’t want to get ExactFlat that I presume has that ‘knowledge’ built-in then I would get close enough to test by redoing whatever the model is as a simplified set of single-curved surfaces that can be unrolled cleanly.
It’s an approximation.
