I tried switching to a black viewport background, expecting better contrast, but found that changing the background alone wasn’t enough.
The Black / White Switching feature looks useful, especially when opening files containing black objects. However, object colors are only part of the issue: hover feedback, markers, highlights, previews, grid lines, and other display elements also need to remain visible.
There seem to be quite a few colors spread across the settings that need adjusting to make everything work together.
Does anyone have a setup they’re happy with for everyday modeling on a black background? I’d appreciate any recommended settings or exported display modes/color schemes.
Hi Stefano,
It sounds like you have already explored Black/White Switching in Rhino 9, but just for clarity - Black/White Switching in Rhino 9 does more than flip object colors. It now also covers:
- Selection highlights and offset previews, so black objects stay visible when selected on a black background (RH-89862, RH-89863).
- Command previews, such as Copy, Array, BlendCrv, Rebuild Curve, and Text (RH-89734, RH-95193).
- Text masks, which now switch with the background (RH-95195).
The switch is driven by the background’s brightness: black curves turn white when the background falls below 30%. More details are in the Black/White Switching post.
For everything else, most of the colors you’ll want to adjust are in Tools > Options > Appearance > Colors:
- Viewport colors: grid lines and world axes. Lighter grid colors with less contrast between major and minor lines tend to work best on black.
- Feedback colors: selected objects, locked objects, feedback, and tracking lines.
- Display modes: each display mode can override the background, so check Tools > Options > View > Display Modes > [mode] > Background to make sure your modes use the application setting or are set to black.
Once you have a setup you like, you can export your display modes from the Display Modes page to share or reuse.
If you are seeing colors that are not able to be adjusted in a way that works well for a dark background setup, or if there is something specific that is not showing up as expected, please let us know and we’ll get it logged, if it’s not already.
I use black background with 25% gray major grid and 12% gray minor grid. Bright yellow for selected objects and white for most feedback UI and modeling aids.
