Creating plug-ins for Rhino requires knowledge of Rhino’s capabilities and programming.
I know how Rhino works because I have been using it for over 10 years.
However, I do not have advanced mathematical knowledge.
I would like to know your opinion on this.
No need for advanced math, knowledge of parametric curves and surfaces is enough for a lot of things, but this depends on what kind of plugins you have in mind.
I see.
I am confident in my knowledge of Rhino because I have many years of experience.
Basically, the plug-in I’m trying to make probably isn’t that difficult. Maybe, but…
I can put a circle of any size anywhere on the surface, make a diamond cutout, etc.
If you haven’t done so already, I would recommend learning Grasshopper. You can define algorithms with Grasshopper and even turn grasshopper definitions into plugins.
Thanks for the advice.
I have an awareness that I am not good at GrassHopper…
Can I define the plugin as a toolbar or icon on the Rhino screen after I have defined it in GrassHopper as you say?
Yes you can, but that is very far down the path. For starters, I would recommend spending some time going through grasshopper tutorials and ask here as you are trying to solve problems using grasshopper.
