Divide points inside triangles pattern
Hi everyone,
I’m trying to create a pattern of circles within a gradient of triangles, see attached image. I’ve been using the Populate Geometry component, but the results are overlapping the shape of populataion points doesnt look good.
Does anyone have suggestions on how to use the Divide Surface component or any other method to achieve better results? I want to ensure that each circle is spaced from the others. and the quantity of circles depend on the area of the triangles so they wont overlap
triangles circles.gh (24.3 KB)
try this offset triangle inside use max radius of the circle as the offset value (a smaller triangle use populate geo and create points and create circles) hope this works
