Divide domain
only one surface is dividing properly other is not. what should I do?
r3.3dm (50.8 KB)
g3.gh (14.1 KB)
Graft the surface input
thank you. but how does this work? I mean I want to know the logic of graft.
You have two surfaces. Let’s just imagine the two surfaces would be different, if just slightly. Or you would want to divide the domains of both surfaces with a different count…
The only way the Isotrim component knows which surface and which domain go together is with a tree.
You can learn more about data trees in the Modelab Primer:
Designing with Data Trees | The Grasshopper Primer Third Edition (gitbooks.io)
thank you so much for the answer!
