Hi McNeel team,
I’m running into an issue in Grasshopper (Rhino Version 7 SR38
(7.38.24338.17001, 2024-12-03) when searching for Divide Domain²
in the component search bar loads the wrong component (Divide Domain
). It appears correctly in search but always places the 1D version.
The Divide Domain²
component also doesn’t appear under Surface → Util.
I’ve confirmed this over multiple attempts and would love to know if it’s a version-related bug or something misconfigured.
Screenshots and sample file can be provided if helpful.
Thanks in advance!
Lucas.
I got some help and have a python script in the meantime, with Type hints on the Python component, with surface set to Surface' & 'u_count
, v_count
set as int
As follows:
import Rhino.Geometry as rg
def divide_domain_2d(surface, u_count, v_count):
u_domain = surface.Domain(0)
v_domain = surface.Domain(1)
u_div = (u_domain.T1 - u_domain.T0) / float(u_count)
v_div = (v_domain.T1 - v_domain.T0) / float(v_count)
doms = []
for i in range(u_count):
for j in range(v_count):
u_start = u_domain.T0 + i * u_div
u_end = u_domain.T0 + (i + 1) * u_div
v_start = v_domain.T0 + j * v_div
v_end = v_domain.T0 + (j + 1) * v_div
dom_u = rg.Interval(u_start, u_end)
dom_v = rg.Interval(v_start, v_end)
doms.append([dom_u, dom_v]) # ✅ just return as a 2-item list
return doms
a = divide_domain_2d(surface, u_count, v_count)
Your images are too small for me to read.
Using the same Rhino version and searching for “di” (“divide”) works fine for me.
