I have a curve that is long, and two points that define a segment within that curve. I want to create that segment as a a new curve object defined by those two endpoints. Is there any way to do this? I saw the divide command but that seems to function a bit differently…
Hello- use the SubCrv
command or the Split
command.
Hi Pascal, thanks for your speedy response. SubCrv worked perfectly. Thanks!
What’s the Domain for this? If I have 2 points on the original curve, and want to trim it or confine the limits to the the 2 points, what is the domain? Tried to construct a domain with the 2 pts, and didn’t work?
Hello - are you working in Rhino, GH, or code?
