Distributed load on a curve
Is it possible to create a linearly distributed load on a curve ?
hey, unfortunately not directly. But you can use point loads and distribute them equally along the curve or surface. The value is then computed by the value of the line load at the point locations times the distance to the next loads = influence area.
Ok, thank you for this workaround.
