Distribute ZAxis?
The distribute command is very useful. But now, I am drawing a bookshelf and I can’t make it work on Z axis. There are only X and Y to choose from and I can’t specify Z as a custom direction.
Use the “Direction” command line option, then draw a vertical line in one of the facing ortho viewports like Front or Right…
HTH, --Mitch
Uhhhh… So many steps for something used frequently.
There are so many things that need vertical distribution and redistribution, I wish for the Z axis to be introduced along X and Y.
Request/bug report submitted…
https://mcneel.myjetbrains.com/youtrack/issue/RH-39798
–Mitch
Distribute uses the X and Y axis of the active Construction Plane. Switch to a different view such as Front or Right with a CPlane with the X or Y axis in the desired direction. Or change the CPlane in the view you are using.
