I made this perforated circular panel in a grasshopper.
The problem with this is the holes don’t have the same distance between each other.
I tried the Collider goal with Kangaroo( just added collision distance to the points), but the result is not evenly distributed points. I guess Collider goal → kangaroo is not the solution.
Is there any pattern or method that can solve this problem? or nearly solve this problem? (somehow I have a feeling it is something that could be solved completely )
Unfortunately it is geometrically impossible to have a combination of: same size holes, holes at set radius intervals from disc centre and equidistant holes. So you have to decide what you are willing to compromise to get an acceptable result.
