Hello - I am not sure I know what you mean - is the starting position ‘un-ordered’ somehow, all objects piled on top of one another? The order should be maintained so moving one object to the end position and having the others in the desired order in between, should get you an even distribution…
Think about a Staircase, the treads should go up in order from 1-10. Mine
are ascending from 10-1, so my first tread is at the top of the Stair
instead of the bottom.
Each tread is a different shape, so I can’t just mirror it.
