Recently I seem to be getting this problem more frequently.
The shape began life as a rectangle (line) and using offset, gumball move and fillet curve, the resulting curves then created the surfaces using loft and PlanarSrf, the result then being joined together.
The issue appears after using the FilletEdge command, previously similar problems have happened after using Boolean Difference to create holes through the item.
I have scanned the forums, but not knowing what to call this, I have probably missed other posts.
Hi Chris, I donât think youâre doing anything wrong - although I am puzzled by the vertical split in that funky-shading fillet surface⌠What happens if you `ShrinkTrimmedSrf?
that last command did sort it, I think Iâm going to have to do some reading on those commands. Could you point me to a document that explains some of these functions.
Hi Chris,
Thanks for that feedback. In an ideal world you wouldnât have to use the help file as a starting point to search other McNeel resources Perhaps this one could be tuned upâŚ
The DivideAlongCreases command divides a surface into separate parts at kinks or tangents.
Creased surfaces are divided into smooth pieces joined in a polysurfaces. Creased surfaces within a polysurface are divided and joined within that polysurface.
(Margaret, the hyperlinked word polysurfaces should be singular).
I suppose that for completeness sake, there should also be a link to an explanation of what tangents are. The explanation for kink has a rounded rectangle as an example. I suppose that this would rather be an example of a tangent. Also, the kink entry is about curves - the command can only be used on (poly-) surfaces.
I guess that the above would explain why you would use one rather than the other.
The initial question - âwhy would you want to use this command at allâ - is not answered in that help entry. I hope that can be changed (but I understand that this would take some resources to get it right).
I hope you donât think that Iâm complaining, working in Rhino is something I enjoy, mainly it just works.
I think I now have a feel for what will work and what will be a bit more playful. But every now and again, something comes along that I assume will be easy, yet proves not to be. The item that triggered this post was made from simple rectangles and some fillets, and yet two versions of it had a similar problem (which I now know how to fix).
While finding an instructional video for creating things in Rhino is easy, finding something on resolving issues is more of a challenge, if for no other reason than Iâm not sure what the problem Iâm having is actually called, so itâs difficult to do a search for it.
I often see commands appear in the list while typing in the command line (?) that I have no idea what they do, so Iâm sure a whole raft of features lurk in Rhino that I would find useful.
@cf53 The âHelpâ panel can kept always open with the âAuto-Updateâ option checked. Then when you run a command it will be available with information about the command and itâs options.
Itâs embarrassing, but explaining WHY you might use a command has been a problem since Rhino -1.0. We never really know why someone would want to use a particular command. Usually a new command comes out of a user having a problem that cannot be solved with the existing tools. Figuring out when it might be useful in other situations is almost impossible. The answers to these questions most often appear in training materials for creating specific object types, and, of course, by asking on this forum.
The reason other commands appear when typing on the command line is so that you donât have to type the whole command name out and to help you if you canât remember the whole command name. What appears is based solely on spelling and has nothing at all to do with the function of the command.
I am commonly experiencing similar issues with surfaces, particularly after Boolean operations. I have been trying to DivideAlongCreases, but this always seems to return with an error. I have used the UseExtrusions command to make sure geometry is Polysurfaces not Extrusions.
I also experience the same issue when Capping objects, particularly sweeps or lofts.
Hi Charlie - can you post a Rhino file with the inputs to the Boolean operation? My guess is this is a render mesh problem that can be cleaned up by changing the setting in File > Settings > Mesh to âSmooth and slowerâ or a custom setting (See https://wiki.mcneel.com/rhino/meshfaq)
I have attached a different file with the same issue (deleted the original). Changing the mesh settings changes some, but not all of the settings.
I have identified that the problem seems to occur most frequently when extruding or sweeping along paths that include both straight and curved lines in the path. Breaking the path into multiple sections helps, but this isnât always possible.
The problem is mainly given by the small front surface (see photo). You must use the _UntrimAll command> keep all the cuts, then â_InsertKnotâ> automatic> both directions, 2 clicks on the mouse. Then cut the surface with the curve (I suggest to do it with the other surfaces too).
On the advice of Pascal, I always do this procedure when I have shading problems (sometimes it is enough _UntrimAll> keep all the cuts)
