Distance Display w/ feet and inches with decimal
Hi! Is there any way to have distance display set to feet and inches, but give you a decimal for parts of inches instead of fractional? that would be my ideal setup.
Thanks!
nscross, you can change the display units in the options of the distance command
This will allow you make a couple command aliases for your preferences
Something like '-Distance U F
Hi, Thanks. I’m not looking to change the units just wondering if there was any way to get a readout like this: 10’2.25" instead of 10’2 1/4" etc. seems like the only feet and inches readout is with a fractional inch.
You’re not changing the Units, you are changing the display of the distance command.
understood, but is there an option with decimal inches that includes feet?
I see, no there is not. It’s either Decimal inches, Decimal feet, Inches fractional or Feet & Inches.
Got it, would that be something we could put in a request for?
I’ve added your request to an already open item.
https://mcneel.myjetbrains.com/youtrack/issue/RH-58537
thanks!
