Hi!
I’m trying to find a way of optimising the solution created by @Joseph_Oster , in order to measure the shortest distance between adjacent curves. As you can see in the image and file attached the more curves included, the messier the annotation becomes. To reduce this I’m looking for a way of reducing the outputs and only making the dimensions to directly adjacent curves visible.
I’m not sure if this could be done by setting a limit on the dimension size, or whether there is a command to maximise the dimensions per curve to only one or two…
Thank you for any help!!
Proximity Curve Dimensions.gh (9.9 KB)
