After typing distance or area in the command bar, I can’t see the result. Also after writing other commands its happening, as an example, I am writing join then it’s joining but it doesn’t write this amount of lines joined etc…
How can I fix this?
Thanks
Hello - it sounds like maybe you need to make the command area a little deeper, maybe?
Haha thank you so much! Solution was much easier than I expected
