The first image with the curve selected is correct showing the supports under the curve. The second image with the curve unselected shows the supports coming through the curve.
Whats happening with the display?
Hi Deborah- can you post the objects in a 3dm file, or post to tech@mcneel.com, to my attention (Pascal), I’ll take a look.
Hi Deborah- I don’t see anything like what you are showing in your images in the file you sent- however, looking again at the images I see the bases for the columns in the right/foreground are shading reversed as well on the first image. I think this may be the AMD video card problem described here:
