Hi everyone,
I am trying to get rid of the diagonal lines that’s running through this polysurface when printing. It’s not a flat surface so some of the diagonal lines are clipped(?).
A couple of questions–
- Is this is a display setting problem and if so–what settings do I need to adjust so that the lines can go away? I’ve adjusting the settings in the Rhino Display and the object property, but no luck
- Is this a modelling problem? Any advice on how to go about modelling this so that it could be clean? The polysurface was previously a mesh that turned into NURB. It’s topography that I exported from Cadmapper.
Unrelated–
Is there a setting that allows me to put a stroke (like Adobe Illustrator) around an object? Ideally, I’d like for the diagonal lines to not show, but the edges to have something like a stroke effect. The print width setting affects both the diagonal lines and the outer edges.
Info: running on Rhino 9 WIP
Image 1: how it looks in model space
Image 2: object description
Image 3: how it looks when printed
