Hi.
objects in the views (perspective, top etc) aren’t being displayed correctly on my laptop, I’ve recently updated it to windows 10 from 7 so that I can use Rhino 8.
Same file is ok on my desktop computer.
Any suggestions on things I can try?
Kind regards
Rob
Run systeminfo and post the results…but err if your laptop came with Windows 7 then it seems really unlikely that it meets minimum specs for V8.
No run SystemInfo in Rhino.
And sorry no every successive version of Rhino since 2015 has placed more demands on the video card, it’s probably way below spec.
So your gpu driver is from 2016, that’s not good, and the gpu itself dates to 2012, that’s…not idea.
Wow! GTX 600 Series on Kepler.
All you can do for now is see of the final release 2019 drivers make your situation any better.
Thank you for pointing me in the direction of 2019 drivers. Rhino 6 worked before updating the driver, now both 6 and 8 work ok.
I will buy a new laptop sometime in the new future!
