Display problem
Hi there!
I have a problem with my display in Rhino, as you can see in the picture, when I go to Perspective mode, the edges are not clean anymore. And it is the same in all view modes (shaded, rendered, arctic,…). However, this doesn’t happen when I’m in parallel mode.
My graphic card is RTX3070, so it’s not because of lack of GPU. I guess I’m missing an option that I can’t find!
Does anyone have any idea?!
Thanks all!
Hi @a.khaeez
Are you - by chance - far from the origin (0,0,0)?
If not, please run the SystemInfo command in Rhino and post the result here.
HTH, Jakob
Thanks @Normand it was exactly “far from the origin” problem since I’m using imported geolocation data!
