I am working on an animation that will use screen capturing / not rendering. I like technical mode, but I use an over-ride material to show a rendered color for the water, which also has some transparency. On one computer (laptop) everything works as it should. But, it refuses to work on the workstation where I plan to do the project.
I have updated the video card, re-done the geometry AND water material, and flipped on & off every setting I can find in the options for Technical and Rendered views.
pascal
(Pascal Golay)
May 7, 2018, 5:31pm
2
Hi Dave -can you export the mode and send it to me or post it here?
What is the system info on the two machines? (Help > System information)
thanks,
Pascal! Thank you for the offer.
Here is the system info on the workstation with issues.
I’ll zip the file and send it directly to your email.
Rhino 6 SR3 2018-3-31 (Rhino 6, 6.3.18090.471, Git hash:master @ b32d93f452fce970e96deb46bfc68b075f06b290)
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Quadro M4000/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 391.33)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-22-2018
Driver Version: 23.21.13.9133
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
C:\Program Files\Bongo 2.0 (64-bit)\BongoUI.20.v60.rhp “BongoUI20v60”
