When I work with breps i i can’t get it to show the linewidth/printwidth of the edges in real time. Only when I try to print it i see it in the small PDF preview.
It works fine with curves and I have also tried to play with the PrintDisplay command.
When you set PrintDisplay state to on it shows the problem. Here is an example of what i see in the viewport and what i want it to show which is the correct print width.
I think you understand me backwards.
I want to be able to see the true print width without having to press print to see the preview. Currently i only see thin lines that should be wide and the print width only works ‘live’ on curves and not on Breps.
If i try to play with the edge settings in artic it becomes universal and also won’t show when using layouts.
But by looking in the background of one of your pictures it seems that it works fine in your viewport.
