Is there a way to display or derive the focii of a curve drawn with the ellipse tool?
Thanks,
Dennis
Thanks,
Dennis
@dmoyes Hi Dennis,
Select it and type What – Object description shows info:
Excellent Fred, thanks.
D
Hello - use MarkFoci
for this.
Even better! Thanks Pascal.
Also, is there such a command as an ellipse from 3 points similar to a circle from 3 points? I have a section of an elliptical arc derived from a section and I would like to determine the full ellipse.
Thanks.
Dennis
I believe that, unlike a circle, there are an infinite number of ellipses that can pass through three points… (correct me if I am wrong) Below is a quickie script that will restore a full ellipse from a partial one (deletes the original).
Edit - this version is a bit nicer, it will let you select near-ellipse curves and has the option to delete or not (option is only visible if no preselection is made).
RestoreEllipse.py (2.0 KB)
Hello - I believe markFoci
will work on an ellipse ‘fragment’, at which point Ellipse
> FromFoci and the Near osnap (the the original curve) will get you the full ellipse.
An ellipse can be determined from four points. http://www.robertobigoni.eu/Matematica/Conics/Ellipse4P/Ellipse4P.html
Yep, that fourth point is the key… Unfortunately, Rhino dos not have a command for that.
4 points isn’t enough to determine a unique ellipse
The link solves with four points only where the axes of the ellipse are aligned with the co-ordinate system axes. You need either a fifth point or the direction of the major axis to determine a unique ellipse.
