Display Modes Restore Defaults
Display Modes Restore Defaults doesn’t work for some modes:
Rhino 9 SR0 2025-11-25 (Rhino WIP, 9.0.25329.12305, Git hash:master @ 94aabd9816971918af23c4e9a3978c27952e558c)
License type: Commercial, build 2025-11-25
License details: Cloud Zoo
Expires on: 2026-01-09
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.9221.0
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 1-26-2025 (M-D-Y). DirectX(11)
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.29 DYNAMIC_ARCH NO_AFFINITY Zen MAX_THREADS=64.
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.25329.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.25329.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.25329.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.25329.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.25329.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.25329.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 9.0.25329.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Hmm, that’s peculiar. I could not reproduce this here. I see that you have some settings that are marked changed, but are default and my guess is that causes it to not trigger it. For example, Ghosted mode transparency is 35 by default, and is marked as changed on your end. What happens if you change that to say, 36 and then click restore defaults?
We had this already.
It seems to work once, but the issue comes back.
Now also other modes are affected.
I’ve made RH-90763 Display modes: Can’t reset to defaults
but as mentioned, I can’t reproduce it here on my end. I installed German language as well but see no differences in behavior with that.
Do you have VisualArq or Lands installed?
No, see SysInfo in 1st post.
I copied the current settings-Scheme__Default.xml to a backup file.
Then made a _Reset.
And then altered the Ghosted mode, quit and restart etc.
I could reset to Defaults flawlessly.
Then I restored my backup xml.
In order to assure that I still can’t reset to defaults.
Surprise surprise, now I can reset to defaults!
Strange.
okay, thanks for reporting back. Glad that sorted it.
edit: FYI the behavior has been changed as a result of this report, see YT
The effect is a revenant.
Again Ghosted only with the 35% transarency.
Rhino 9 SR0 2025-12-9 (Rhino WIP, 9.0.25343.14055, Git hash:master @ b75d898fa0597c4156f05418133dc1d4fc315abc)
License type: Commercial, build 2025-12-09
Expires on: 2026-01-23
None found.
DirectX Settings
Safe mode: Off
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.25343.14055
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.25343.14055
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.25343.14055
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.25343.14055
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.25343.14055
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.25343.14055
C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 9.0.25343.14055
Seems ok now in (9.0.26055.12305, 2026-02-24).
Strange.
