Mine shows 95 percent for transparency. Is that correct? Thanks, Mark
Also noticed, there is no polygon control as solid line
Hi Mark,
Transparency should be 0% by default for the Shaded display mode. Have you tried restoring the mode to the defaults in Options?
Can you explain more about what you mean by polygon control as solid line?
Yes I did. But it reverted back to 95 percent as default. Only wanted to see if it was just me. Thanks,Mark
BrianJ McNeel
June 14
Hi Mark,Transparency should be 0% by default for the Shaded display mode. Have you tried restoring the mode to the defaults in Options?
I didnt see your bottom question to mine. Yes, the polygon control lines. They are dashed with no way to make solid, correct?
Visit Topic or reply to this email to respond
To stop receiving notifications for this particular topic, click here. To unsubscribe from these emails, change your user preferences
