My shades for a surface are not visible it only shows wireframe objects even after using loft or any other command i tried going to the display mode but there i dont have shaded or ghosted options under the display mode instead i only have wireframe mode ,i tried restoring and re installing again but its not working and alos everything is in update so now i dont have any idea what to do so anyone pls help me out
I found that the Rhino 8 runs under safe mode in your current device, could you try to run it as the normal mode ?
Actually i was able to do it in the safe mode earlier sir can u pls tell me what problem im facing?
In safe mode, viewport shading is disabled. You can run SetDisplayMode in the command line of Rhino 8, you will find that you only can choice Viewframe. More details about Safemode please visit below page
Thank u sir
