I use a customized displaymode but have a different output in my topview. As you can see the carpet is not shown in my topview but the same displaymode is set. Every viewport shows it properly except my topview. For making a floorplan it’s very annoying this problem shows up. Does someone has a solution for this?
Hi -
Without a simple test file and your display mode, it’s hard to know what might be going on here. Perhaps you could try some different settings for the ground plane?
Hello Wim,
I uploaded the testfile and displaymode. I tried different groundplane settings but no result. As you can see in the test file it looks like the surface in the topview is only shown as an outline curve you can look right through it.
Hello - the object has it’s own display mode set - use SetObjectDisplayMode
> Use View to restore it to default behavior.
Thanks, that solved the isue.
